maf
  • paulmac
    • Dec 2006
    • 306
    maf
    Hi all, looking for a few pointers,am upgrading 2 a tubular manifold and bigger turbo on the aan engine, and i would like 2 relocate the maf 2 the pressure side i would also like 2 install a bov on the presure side, any advice on wats involved, would b great, i also noticed the new hybrid turbo has no nipple for the small hose that feeds in2 coldside on turbo wgfv i think ,so any advice on that would b helpfull, thanks in advance paul.
  • paulmac
    • Dec 2006
    • 306
    maf
    Cant find any threads on this, anyone?
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      for the turbo,you need to drill a small hole on the cold side and make a nipple.
      For the maf you need to remap once you have done that as the car wont really work and also fabricate a way for the maf to stay in position as it will be easily blown off due to pressure.
      • DJones
        • Jun 2005
        • 2020
        You will also need to fill the electrical area (under the cover) with epoxy resin as its not air tight under boost.
          If you decide to put the MAF mechanism into a metal tube you must use the same diameter as the original or it will not be mappable.
          • paulmac
            • Dec 2006
            • 306
            maf
            I was thinking about fixing the maf in2 a metal tube thus replacing the plastic caseing, has this been done, also the vacum hose 2 the nipple on the front of turbo wat exactly does this control and can it b done away with,or changed,thanks for replys guys
            • Smiley
              • Jun 2005
              • 329
              It may be possible to place the nipple to some place after the turbine? maybe to the maf housing in this case? should work..
              '93 Audi S2 Avant panthero black, 412.000km
              '94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
              '93 Audi S4 C4 Avant, 260Tkm
              '88 Audi 100 Avant turbo 44Q
              '84 Audi 80 quattro tornado red
                Re metal MAF tube read my post above ^^
                Nipple on turbo is the feed to open the wastegate, you need that Just drill and tap it.
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  the nipple on the turbo cold side is best to be situated as close to the beginning of the cold side as possible.If placed after the turbo or at the end you may have problems with mapping(nothing serious,its is just how well it reads the pressure built from the turbo.thats all)
                  • paulmac
                    • Dec 2006
                    • 306
                    maf
                    COOL, any pics of this setup, cheers guys
                      Here you go.
                      [IMG][/IMG]
                      • DJones
                        • Jun 2005
                        • 2020
                        Hope it helps.
