3" Centre Box
    3" Centre Box
    I'm looking to add a centre box to my 3" system, 034 recommend one which is 3" in and out Here but its over 117 bucks and the shipping is another 70. Its a flat oval with both in and out offset the same way. Where can I get one like this or similar? I've looked at DTs and they only have cherry bombs in that size. Also looked at Magnaflow and Borla ..
  • DJones
    • Jun 2005
    • 2020
    Originally posted by newsh
    I'm looking to add a centre box to my 3" system, 034 recommend one which is 3" in and out Here but its over 100 bucks and the shipping is silly. Its a flat oval with both in and out offset the same way. Where can I get one like this or similar? I've looked at DTs and they only have cherry bombs in that size. Also looked at Magnaflow and Borla ..
    Have a look on the Jetex website they do quite a range in mild and stainless.
      Cheers for that, looks like they do some good stuff.
      They even do a rear box for the S2 which fits to stock pipework!Here it is. Not that I need one of those of course..
        Do you know if the tail pipes have internal perforations?
          Prospeed would make something like that for you while you wait shame they're in Cardiff. What about NoLife?
          • Taagom
            • Aug 2007
            • 20
            Hello
            LINK
            I tried to fit the TURBO 76 model on my coupe, but the 140mm diameter and 500mm lenght was to much to handle. I ended up fitting two TURBONETT 76 replacing the cats.
              I was wondering if one of these will fit?
              Linky to Jetex Stainless 3"
              Turbotight76
                Originally posted by Taagom
                Hello
                LINK
                Did it get rid of the BOOM between 2k5 and 3k?
                • Taagom
                  • Aug 2007
                  • 20
                  I haven´t had a chance to drive my car with the new exhaust. But at idle it sound better than before (one big box vs. two small ones). I´ll try to rev the car tomorrow and let you know about the booming sound.
                  250x220x140 box would replace one cat, but the connection pipes at both ends are too long. (easy fix)
                  • Taagom
                    • Aug 2007
                    • 20
                    When revving the car at 1500-2000rpm it sounds like a rally car / 3'' exhaust evo. No booming at 2500-3000. I have some small leaks to take care of.
                      No cats to worry about for Mr. Newsh
                      Hoping that with a sports cat mine will be just right with one big bloody box at the back.
