Yeah think Slow2 is running the Zeitronix system.
Anyhow Zeitronix states the following their instructions http://www.zeitronix.com/installatio...structions.pdf
The Wideband Oxygen sensor must be positioned after the turbocharger and before the catalytic converter. Recommended installation
requires welding the O2 sensor bung in the down pipe at least 16” away from the turbo. A stock narrowband O2 sensor location is
usually too hot for the wideband O2 sensor. The oxygen sensor must be positioned vertically (wires pointing upwards between 10 and 2
o’clock) to prevent cracking of the sensor ceramic element and protect sensor against water condensation.
