Vr6 Maf
    #31
    Its not diameter that concerns me here - it is potential for totally different MAF output curve which at best would require some remapping, or at worst may provide such a limited dynamic range that it is unsuitable for the S2 application. I fricking hate the way we can't get MAF data from Bosch - its all locked away in a safe like the crown jewels. Irk.
    • cquattropower
      • Feb 2009
      • 270
      Ok so nobody is recommending that I go with the vr6 maf, so wheres the best place to get a s2 maf from?
      • Rusty
        • 18953
        Have a search for the RS2 MAF, they were going for about 130. Also check out the threads mentioning TPS from S2avant for a good deal
        • Animal Mother
          • Jul 2007
          • 1135
          I should still be able to get the original price quoted. I'll check if you are interested.
          UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
          Triumph Daytona 955i - mmmmmm :fire:
          80 dag dag :driving:
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            #35
            can you get an RS2 maf on a cheap price as well?
            • Animal Mother
              • Jul 2007
              • 1135
              I'm not sure but I'll check if you are still interested.
              Do you definately need an RS2 one? They are basically the same unit.
              • A80Avant
                • Sep 2005
                • 10873
                • Country: Greece
                #37
                well,i think the RS2 one with the plastic mesh is much better.I have used S2 ones in the past,and the car did feel different with the rs2. Besides the car is an rs2,so i should stick to that
                thanks
                • Knight Rider S4
                  • 3541
                  My S2 Avant is running a dream..still has the VR6 MAF in it ...no complaints here
                  93 S2 Avant Parting
                  91 URQ RR
                  02 A4 tdi Avant
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    #39
                    The turbine wheel is still there ATM then?
                    SS
                    • avants2turbo
                      • Feb 2008
                      • 1287
                      What map are you running, have you checked the AFR?
                      • Knight Rider S4
                        • 3541
                        You mean the whining noise ...Just got use to that
                        93 S2 Avant Parting
                        91 URQ RR
                        02 A4 tdi Avant
                        • Knight Rider S4
                          • 3541
                          Running a MTM style one similiar to yourself ....Warp Factor 9 ....Have not had a chance to do any measurements but will be using vag.com and see what the difference between 2 when i get a chance
                          93 S2 Avant Parting
                          91 URQ RR
                          02 A4 tdi Avant
                          • avants2turbo
                            • Feb 2008
                            • 1287
                            Im glad to see i wasnt the only one that thought the VR6 maf made such a huge difference, it was so noticeable when i did it, shocked me, and it was only done out of necessity as id put my finger through the hotwire on my s2 one, and my mk2 vr6 just happend to be sat there...
                            • Rusty
                              • 18953
                              For <£100 you'll be able to spend an hour on a RR and test this properly with all the correct equipment around, gotta be cheaper than melting an exhaust valve or piston if it is lean as phook If it is an upgrade then I guess it can get named like the MarkH mod Fame or failure awaits...
                              • avants2turbo
                                • Feb 2008
                                • 1287
                                tis true, and to be honest, if the avent was running now, i would do just that.....
