problem with intake manifold & throttle
  • ChO^4Ko_BG
    • Dec 2008
    • 13
    • Country: Bulgaria
    I assemble ААN engine with 3B intake manifold and AAN throttle.I've changed the ventil's cover with that from ABY .Тhe problem is that the throttle touches in the ventil's cover and I can't understand where is the problem - in the throttle or in the intake manifold Is there any difference in the sizes between 3B & ABY intake manifold ,AAN and another throttle ?
    Greetings!
  • rs200
    • May 2009
    • 1398
    • Home: Croatia
    when i want the same think to do on my 3b i have a problem with distributor cap.
    but i used 3b throttle,rs2 manifold,s4 ventil cover.
    i have to cut a piece of distributor cap.
    mabye is some diferent between rs2 and s2 manifold
    • rs200
      • May 2009
      • 1398
      • Home: Croatia
      i went too locke a little bit closer.
      it is inposible to put 3b intake manifold on aby ventil cover
      you must find out a aby manifold ,or adu manifold.
      but you CAN NOT put a ABY manifold on AAN ventil cover ,but ADU you can.
      the throttle is not the problem.
      • ChO^4Ko_BG
        • Dec 2008
        • 13
        • Country: Bulgaria
        Тhanks you for the reply
        • Serzyk
          • May 2007
          • 4
          • Country: Ukraine
          AAN Cover with 3B Intake & Throttle
          • kwlw
            • Sep 2004
            • 1025
            • Country: Lithuania
            Nice job.
            Sau
