Hi.
Just wanted to know what reversed manifolds there are available for an I5 20vt?
AFAIK: wagner-tuning, furans.. are there any more? If there are, please write them down and add some pictures
that was a replica just as i have.
i had it checked and it needs modifications to fit.Also according to Carsten the injector angle is slightly different and so i will use the OEM inserts with a bit of grinding taking measurements from the OEM inlet.
aronmatic used on of those in the early days, ran it on a car making 750hp. no problems with the angle of the injectors(he didnt alter them at all) and only had to modify the manifold to fit the pas pump.
lets not disregard something just as easily. Ill give it a try and if it doesnt fit or makes things difficult ill get the original thing. Simple as that! Since i have it,id rather check it before throwing it to the bin
and yes we did try it on an rs2 a few weeks ago. it doesnt need huge changes.
Injector inserts is a good option as well, as you can modify the angle to match the original and you also dont damage the rubber injector seals when inserting the injectors through the aluminium holes
No he didn't, he ran a Hacke manifold, then changed to said manifold and the engine blew up on the rollers at 500 bhp
How someone can promote a copy I don't know, the MTM, Wagner, Dahlback variants all are optimised.
