Reversed intake manifolds
  • max_s2
    • Mar 2006
    • 498
    • Country: Latvia
    Hi.
    Just wanted to know what reversed manifolds there are available for an I5 20vt?
    AFAIK: wagner-tuning, furans.. are there any more? If there are, please write them down and add some pictures
    Wagner-tuning:
    Furans:
  • s2_bo
    • Oct 2005
    • 6067
    Not sure who made this one but its was quite cheap!
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=170380340347
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • A80Avant
      • 10873
      • Country: Greece
      that was a replica just as i have.
      i had it checked and it needs modifications to fit.Also according to Carsten the injector angle is slightly different and so i will use the OEM inserts with a bit of grinding taking measurements from the OEM inlet.
      • max_s2
        • Mar 2006
        • 498
        • Country: Latvia
        who has made it? However it looks nice.
        • s2_bo
          • Oct 2005
          • 6067
          Ahh ok, was that a good price then considering its a copy?
          91 S2 coupé - RIP
          • A80Avant
            • 10873
            • Country: Greece
            i got it from a friend in greece for silly money,but they usually end up around 500euros from ebay auctions
            • Lupo911
              • Apr 2005
              • 312
              Have you ever tryed to put them on a Car? Have you ever seen a car running good on that one?
              What is it worth to you to have less Power then before or even a broken Engine?
              Again, the Injector Angle is wrong, its not Spraying to the Valve... FAIL
              the PS Pump does not fit... FAIL
                There are only 4 proven choices I would use on the I5
                Wagner
                Pro-Mo
                Furans
                AAN ( requires rad relocation )
                • A80Avant
                  • 10873
                  • Country: Greece
                  aronmatic used on of those in the early days, ran it on a car making 750hp. no problems with the angle of the injectors(he didnt alter them at all) and only had to modify the manifold to fit the pas pump.
                  lets not disregard something just as easily. Ill give it a try and if it doesnt fit or makes things difficult ill get the original thing. Simple as that! Since i have it,id rather check it before throwing it to the bin
                  • A80Avant
                    • 10873
                    • Country: Greece
                    and yes we did try it on an rs2 a few weeks ago. it doesnt need huge changes.
                    Injector inserts is a good option as well, as you can modify the angle to match the original and you also dont damage the rubber injector seals when inserting the injectors through the aluminium holes
                      No he didn't, he ran a Hacke manifold, then changed to said manifold and the engine blew up on the rollers at 500 bhp
                      How someone can promote a copy I don't know, the MTM, Wagner, Dahlback variants all are optimised.
                      • jogi730
                        • 2335
                        Pro-Mo
                        And read this
                        Audi 90 quattro (Typ 85)
                        20v turbo conversion
                        • A80Avant
                          • 10873
                          • Country: Greece
                          check with aron jamo. he is not talking about his car. he has used a replica without issues. i know about the hacke manifold
                          • 4WheelDrifter
                            • Oct 2004
                            • 5773
                            • Country: Devon
                            Originally posted by Jamo
                            http://www.s2forum.com/forum/showthread.php?t=18723
                            Wagner
                            Pro-Mo
                            Furans
                            Hey. You forgot MTM/DBR.
                            Now only 1190€/1626€ respectively.
                            Although they were much cheaper in the old days when the € was weaker against the £.
                            SS
                            • Billman
                              • 4129
                              The Pro-Mo one is a dual chamber design and fits with Air-con etc on left hand drive cars?
                              Go Holset or Go RS4
