You can see it on the illustration - the outer disc is not in your pic.
And the wastegate comes as one item - you can not buy seperate parts for it. i found that out when I tried to get a cup and shaft for it - you have to buy the complete item!
There isn't a gasket so you need the lip to seal to it.
Question for anyone reading. I had an exhaust manifold (10vt) ceramic coated, and the sealing surface for the wastegate is not as smooth as it was when it was bare metal.
I'm thinking I may have to sand, smooth, or polish that surface to get the wastegate to seal up against it. I suppose I could find out when I run the motor, but does anyone care to speculate on whether it will be okay without some sort of modification like sanding?
Not trying to hijack the thread!
By the way, I have a wastegate that I've lost that same piece to. In the meantime until it shows up again, I've bought another WG.
Kenneth
1990 Coupe quattro
1991 200q20v x 2
1985 4ksq 20vt project
1986 Coupe GT 10vt project
2006 Honda Ridgeline
1998 Honda VFR800FI
