wastegate installation on a new headers
  • timucin
    • Nov 2003
    • 869
    • Country: Turkey
    i am trying to finish my half headers project,
    but what i dont know is
    there is a round steel under the wastegate which seats on headers flange;
    does this round steel has to have 0 gap with its seat?
    cause what i have(flange) ,has bigger radius then wastegate round steel
    Quattro
  • timucin
    • Nov 2003
    • 869
    • Country: Turkey
    here is pic
    Quattro
    • timucin
      • Nov 2003
      • 869
      • Country: Turkey
      pic2
      Quattro
      • timucin
        • Nov 2003
        • 869
        • Country: Turkey
        3rd pic
        Quattro
        • timucin
          • Nov 2003
          • 869
          • Country: Turkey
          is this ok?
          o0r do i have to cut the flange with wastegates round steels bore?
          thnx for help
          Quattro
          • timucin
            • Nov 2003
            • 869
            • Country: Turkey
            need help here;
            i got welder on my one hand and trying to push computer buttons with the other hand,come on help forum members i gotta weld this
            Quattro
            • Mark Halligan
              • 2001
              need help here;
              Timucin,
              looks like you are missing a bit there. There is another part to the wastegate, a round ring that sits in the bottom where it meets the flange.
              Mark.
              Mark - Modded
              • timucin
                • Nov 2003
                • 869
                • Country: Turkey
                i dont have any other part here;
                do you have pic of that part?
                Quattro
                • Mark Halligan
                  • 2001
                  I will have tonight when I get home, I'm at work at the moment.
                  Mark.
                  Mark - Modded
                  • timucin
                    • Nov 2003
                    • 869
                    • Country: Turkey
                    ok thnx too much
                    Quattro
                    • Doug_RS2
                      • 3847
                      I agree with Mark.
                      Your metal flange needs to have a lip to seal against the wastgate. It should not be a tight fit against the part that moves.
                      There isn't a gasket so you need the lip to seal to it.
                      But you are missing a ring that fits tight round the moving part as well. It's confusing to describe - better with pictures.
                      • timucin
                        • Nov 2003
                        • 869
                        • Country: Turkey
                        i can not find anything on etka
                        Quattro
                        • Doug_RS2
                          • 3847
                          You can see it on the illustration - the outer disc is not in your pic.
                          And the wastegate comes as one item - you can not buy seperate parts for it. i found that out when I tried to get a cup and shaft for it - you have to buy the complete item!
                          • auditude
                            • 407
                            Question for anyone reading. I had an exhaust manifold (10vt) ceramic coated, and the sealing surface for the wastegate is not as smooth as it was when it was bare metal.
                            I'm thinking I may have to sand, smooth, or polish that surface to get the wastegate to seal up against it. I suppose I could find out when I run the motor, but does anyone care to speculate on whether it will be okay without some sort of modification like sanding?
                            Not trying to hijack the thread!
                            By the way, I have a wastegate that I've lost that same piece to. In the meantime until it shows up again, I've bought another WG.
                            Kenneth
                            1990 Coupe quattro
                            1991 200q20v x 2
                            1985 4ksq 20vt project
                            1986 Coupe GT 10vt project
                            2006 Honda Ridgeline
                            1998 Honda VFR800FI
                            • Mark Halligan
                              • 2001
                              Timucin,
                              here it is
                              Mark - Modded
