RS2 Porsche 968 MAF
  • alg
    • Apr 2004
    • 1160
    RS2 Porsche 968 MAF
    Just some advice. The RS2 came with a reciept indicating a MAF fitted end 2003. Detailed as Porsche 968 no 0280213017 (which corresponds to RS2 part no ) @ £170.
    Is this correct for car ( I assume so ) ?
    Can this be improved on with standard engine e.g use Sport Quattro (M5/928) MAF ?
    Is this a good price for RS2/S2 owners looking to replace/upgrade ?
    I have not dismantled it to comment on mesh configuration etc
    Oh and a final question, would a 968 turbo MAF be different/better/compatable?????
    Cheers in advance
    Alastair
    RS2
  • audiman
    • 4827
    SQ uses the best MAF, but its wiring is different, and due to it being so rare, no wiring diagrams can be found
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • John Speake
      • Nov 2007
      • 2
      Yes the SQ uses the same MAF as the 928. I can supply the wiring of the 6 way plug, which is different to the RS2 device.
      Then you would need to remap to the 928 MAF, which I know some RS2 people have done in America.
        Alternatively, can the RS2 MAF be fitted to a larger tube... and then the ECU remapped to that ?
        Paul
        • AndyP
          • 6049
          Paul
          OMG, 'can of worms' springs to mind
          • BRY
            • 3755
            Alternatively throw the maf in the bin and use an ECU which doesn't use one.
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              http://www.s2forum.com/forum/showthr...ght=carbon+MAF
              Nicely dug up John Speake.
              Tekkno's carbon MAF tube.
              Audi Sport quattro, Porsche 928 and BMW E34 M5 all share the same MAF BTW, Bosch 0 280 214 001.
              SS
              • pastures16
                • 2058
                tell us more then
                94 s2 avant
                aoc member 1116
                  I've actually held that MAF, was suppose to come home to Birmingham but it didn't.
                  I lost sleep for weeks
                    Paul
                    Apparently thats really difficult, even Prof. Motronic baulked at that recently.
                      Oh yeah as my uncle Tommy used to say - Just like that !
                      • BRY
                        • 3755
                        How much would a "live" re-map be to use the big tube MAF?
                        How much would the big tube maf cost?
                        How long would it take Samco to produce the big tube Maf hose? :mischeif:
                        Uncle Tommy was right wasn't he?
                          Just read the whole of that "carbon maf tube debacle" interestingly, several years later, Mihnea still won't map a car with a MAF element fitted to a bigger tube than it was designed for, thats as of last week.
                            Is this because Bosch make it so damn hard to find accurate data on the MAF devices ?
                            You would need an accurate flowbench to plot the voltage output from a MAF residing in a custom / larger tube so as to characterise it properly... WIthout that you would just be in a land of guesswork.
                            From additional exchanges with the man from JDS he tells me that his flowbench runs at 12 nominal rates but does not provide an exact / accurate cfm measurement. Using a known fresh/healthy MAF builds up a voltage profile at those 12 speeds which is then used as the reference point for testing and calibrating other MAFs.
                            I have a cunning plan to see if I can calibration data from the JDS rig - but it might be expensive as it needs a reference MAF to provide a voltage that correlates to Bosch factory data for a reasonably accurate indication of airmass flow.
                            If we know the profile of MAF voltage to air mass then we have a pretty accurate indication of engine power at any given operating point on the engine. Watch this space - it might come to nothing - but its worth a rattle.
                            Paul
                            • Flat on my back
                              • Jan 2007
                              • 2449
                              Surely 'freedom of information rights' in the States could help on this matter?
                              Carlos.
