I finally got my car put through an emissions test with no CATs on and it failed!!
results were:
1st test
co 0.97% - fail
hc 57ppm - pass
lambda 1.007 - pass
2nd test
co 0.75% - fail
hc 63 pm - pass
lambda 1.006 - pass
Natural Idle test
co 0.69% - fail
Is there something wrong with the car? What could cause high CO levels (apart from having no CATs). Paul N you suggested that it should easily pass with no CATs, do you know of anyones car that has?
Also I got the definative judgement on whether a car needs CATs for an MOT. If a tester is in doubt get them to call the Vehicle Inspectorate MOT Helpline on 0845 600 5977, I did and was told:
'There is no part of the test that requires the tester to check wether CATs are fitted to a vehicle. The car is only required to pass the emsissions test but it would be unusual if it did without the CATs'. How right they were...............
So now I have to refit my wierd smoking CATs unless anyone can suggest a way of getting the CO levels down
Leigh
results were:
1st test
co 0.97% - fail
hc 57ppm - pass
lambda 1.007 - pass
2nd test
co 0.75% - fail
hc 63 pm - pass
lambda 1.006 - pass
Natural Idle test
co 0.69% - fail
Leigh
