No cats = Failed emissions test!
  • dan_b
    • Sep 2003
    • 3670
    My 1991 de-catted S2 had its MOT today.
    passed the emissions test fine (as it should - it's only cars registered since 1992 that are subject to a more stringent emmissions thresholds in the test with the only technical way to get through them being a functioning Cat), but failed on dodgy indicators - water in the rear light clusters. Argh!
    The rotten egg smell is common with cars with Cats when they're running from cold. It's to do with high sulphur levels in European petrol, incomplete combustion due to cold-running, a not fully-warmed up Cat not catalysing effeciently, resulting in the Cat producing Hydrogen Suphide (the egg smell).
    I think the only way to get round it is to try using different petrol, and maybe if it still persists, ditch the Cats completely, or get new ones that will be more efficient.
    Also, in theory, a Cat can actually INCREASE the levels of CO2 produced as it catalyses reactions various emmissions to CO2 and water.
    It's the 1992 threshold that's significant I believe.
      • 12431
      to get rid of the eggy smell its usually because the engine hasnt been opened up for a while, after its warm obviously.
      so give your motor a bit of a thrash and should clear the cat out.
      found the leak on rear cluster onmine to be thru the four retaining screws for the black plastic panel across the boot.
      took the tops off and sealed the screws etc in with somesilicone sealant and syphoned the water out of the passenger side light
      • dan_b
        • Sep 2003
        • 3670
        My 1991 de-catted S2 passed it's MOT - here are the emmissions figures
        CO 0.82%
        HC 181 PPM
        Gotta love those pre-1992 regulations
        • audiman
          • 4827
          Pre 92 is the best way, it doesn't matter (to a limit) what comes out the back
          Tom C - www.rcmr.co.uk
          Audi UR Quattro
          Audi 100 C3 2.0 5 cyl 115ps
          Audi B5 RS4 645ps 911nm
          • s2driveruk
            • 12696
            Just got mine back through the MOT after feckin around with the steering rack gaiter...just fyi, 1992 catted s2 3b:
            Fast Idle test
            CO: 0.00%
            HC: 5ppm
            Lambda: 1.010
            Natural idle
            CO: 0.24%
            David
            1992 3b S2 Coupe
            • audiman
              • 4827
              Perfect results, David!! Glad to see the old 3B is running ok.
              Audi UR Quattro
              • s2driveruk
                • 12696
                and now just the brakes, alloys, turbo to sort plus working out a way to get the wheel liner bolts holding the bumper on undone so i can get the belts and oil pressure sender changed then i am there.....
                Hopefully yours will be on song again soon Tom, have mine out on the track next spring too
                David
                1992 3b S2 Coupe
                • Doug_RS2
                  • 3847
                  #23
                  I have used mole grips to hold the stupid threaded shaft that comes away from the metalwork.
                  Are you still getting the RS4 18s?
                  • Lee
                    • 1512
                    Has anyone's ABY passed the UK MOT without cats? Or is this definately only possible on the pre-1992 cars?
                    Lee
                    Designun Limited....
                    • akojacko
                      • 107
                      #25
                      mine got through last year with previous owner . it must be a fiddle somehow coz it wont meet emissions without the cats . he told me to go back up scotland for next mot if i cant sort owt out down ere' in yorkshire ..lol. considering u need a printout etc , god nows how he pulled it off . must turn a blind eye and fiddle somewhere. i have both the cats sat in the garage and he definatley didn't av em on 4 the mot. i need mot next march so need to sort something out soon as i dont really want to put cats on just 4 the mot test. :
                      ako
                      • audiman
                        • 4827
                        The MoT centre has to keep a copy of the gas test results for upto 3 months.
                        You could for example use another car for the gas test and just enter the details in as another.
                        Audi UR Quattro
                        • Sweeper
                          • 1317
                          • Country: Latvia
                          #27
                          Or buy a sport cat from certiefed sellers
                          Vadim.
                          • audiman
                            • 4827
                            Dont start all that again sweeper!!! LOL
                            Been there, done that. But NO I dont want the t-shirt, or a CAT.
                            :nana: :nana:
                            Audi UR Quattro
                            • akojacko
                              • 107
                              #29
                              thats probably it audiman. !!!!! so just need an enthusiastic mot tester then....mmmmmm.:eek2:
                              ako
                              • audiman
                                • 4827
                                There would be a massive penalty for the MOT station if this was done. Could lose their license! I work for my old man, so its in my best interests not to do anything that could jeperdise his company, if i want to live in his house that is!
                                From my point of view, its not worth me taking the risk. The Vehicle Inspectorate have a new way of testing MOT standards. They randomly turn up at your garage and re-mot a car that you have done on that day. I had one on Friday. they checked a car that I did in the morning. I got given the all clear and they went to another station.
                                PS Why is there not a 'bricking it' smilie!!
                                Audi UR Quattro
