Boost Cutting
  • Sonic
    • Jul 2006
    • 5514
    Boost Cutting
    Got the classic boost cutting with overboost protection... again...
    Sometimes i can drive the car for a few minutes at full pelt, but eventually it gets to the point where anything above .5 bar at WOT causes it to boost cut.
    Not using WOT or putting into valet mode with the switchable ECU lets me drive fine.
    The car battery recently ran down, since then the idle has been awful on startup, flicking up and down between 500pm and 1500rpm on the rev gauge, and up and down on the boost gauge. Not sure if this is the same issue.
    I've reconnected the N75 and checked lots of vacuum pipes to no avail.
    VAG-COM tells me the following:
    5 Faults Found:
    00561 - Mixture Adaptation
    13-00 - Adaptation Limit (Mul) Not Reached
    00544 - Shareware Version. To Decode all DTCs
    27-10 - Please Register/Activate - Intermittent
    00537 - Shareware Version. To Decode all DTCs
    08-10 - Please Register/Activate - Intermittent
    01262 - Solenoid Valve for Boost Pressure Control (N75)
    31-10 - Open or Short to Ground - Intermittent
    00513 - Shareware Version. To Decode all DTCs
    03-00 - Please Register/Activate
    I've ordered a boost pressure test kit from Andy, so will see where i get with that. But can i just disconnect the MAF and go for a drive to test that?
    S2Forum.com Administrator
  • A80Avant
    • 10873
    • Country: Greece
    you may be having a N75 problem there. Have a look at it to see if it is broken or something causing a boost leak.
    I think i may have a spare somewhere..
    • Le S2 Audi
      • Jul 2009
      • 3805
      Have you tried to reset the ECU by pulling the fuse's???
      New S2 - S8 & RS2 -RS6 Keyrings
      • Sonic
        • Jul 2006
        • 5514
        I removed the ECU including the big connector and reconnected the vacuum pipe, making sure it wasn't bent over itself.
        Should could as resetting the ECU
        • BRY
          • 3755
          Have you tried a different battery?
          • Le S2 Audi
            • Jul 2009
            • 3805
            Did you get the errors before or after unplugging it?
            I would just pull the fuses (I assume you know which ones to pull... Big Twin One With Motuer On the Top...) and as Bry says try another battery...
            • s2_wot
              • Aug 2006
              • 2178
              @ Sonic, for what it's worth I had the following sequence of failures and the horrible idle sounds familiar to me..
              Boost Leaks causing that cut in power. Then failure of the temp sender on the coolant rail and failure of the relay that controls the after run pump which I think killed battery #1.
              Battery #2 went because of a knackered alternator. Before the alternator finally gave up the idle engine speed was horrible. It was like she was just limping along. I also blame a dodgy cd changer on killing off the battery.
              HTH somehow
              Shane
              Shane
                I've had issues this week since a battery run down the other day
                Idle was awful and it was running lumpy at times but was like a scalded cat at WOT.
                I then realised that I'd swapped the MAF when I went back to my airbox (from cone filter) so had a look at it... the MAF in there was filthy! Have put my spare clean MAF on so see how that goes while I clean this one up. Otherwise I might have knocked something like a plug or wire... ah well
                  Maf connector or boost leak.
                    Cleaned the MAF and all is well, it was really bad - I can only guess that the volcanic ash has made the job of the air filter especially difficult...
                    • europeanme
                      • Oct 2005
                      • 3817
                      thats scary, as I was going to post about a running issue....over boost cutting in....really bad idle speed...but my voltmeter is reading 14 or very slightly under so i would be amazed if my battery is on it's way out....
                      I will watch this post with great interest...
                      Mike
                      • Orion
                        • Apr 2008
                        • 61
                        And I've got the same problem too 4000rpm fuel/boost cut off Car's in the garage today getting fixed
                        • s2_bo
                          • Oct 2005
                          • 6067
                          Good luck Andy,
                          If you want to try a new N75 let me know. I have 2 left.
                          Its prob also worth cleaning the maf like Andy said.
                          91 S2 coupé - RIP
                          98 S8 - Luxury barge
                            • Sonic
                              • Jul 2006
                              • 5514
                              Originally posted by s2_bo
                              Good luck Andy,
                              Cheers Bo, how much?
                              My plan is to clean the MAF, pressure test for boost leaks and try a replacement WGFW.
