Milltek system vs. OEM
Some shots....
I had to visit the factory to have about 3" chopped from the system to ensure it fitted properly. You can see the 'before' and 'after' shots of the tailpipes. Based on my personal experience the Milltek system does not fit correctly from the box. We found when initially fitting up, to get it to clear the drive shaft/roll bar/subframe etc it hung down way too low at the tail pipes and also stuck out way too far. You could almost trip over it once it had heated up!
Nevertheless, Milltek's customer service was excellent and Phil offered to modify it to fit properly, which took a few hours in Nottingham. I am one very happy customer and for the record have not noticed any booming or droning with this setup.
The Milltek is also hugely lighter than the OEM system - easiest way to save some KG's!
Some shots....
