So after the track sessions yesterday, car was idling poorly, actually stalling on a couple of occasions on the way home.
Added to that it had decided to eat 1/2ltr of oil and on warm starting, was greeted with a cloud of white smoke On the final session I did, it felt low powered 2-3 laps in and on looking this morning there appears to be black sooty spots over the back of the car so i have a boost leak too
Anyway, removed the airbox to get at the Lamda to sort the stalling/poor idle issue, this is what it looked like:
It was dry and lightly wire brushing it the brown (burnt oil???) came off
I had run the car for a few seconds before removal to see if it belched more white smoke from true cold start and nope plus it idled ok too - what does that mean then
I could see once the maf was removed that the intake path was soaked in oil:
intake to MAF
off the metal pipe from the I/C to the one over the rocker was literally dripping in oil
Kinda answers where the oil was going then...PCV..which if the oil was pooling in the I/C would have driven up the AIT temps which may had made the car feel lumpy/low powered i guess
I whipped off the PCV valve and it looked clean enough and there was plenty of oil in the pipework - the whole circuit was replaced in the summer so its not gunky etc Would it be a faulty valve causing the oil to get round in big amounts? the valve has a date stamp of 2007 so its not old (less than 5k miles I'd guess)
Sooooo, what would cause the white smoke at hot startup? I hadn't run it at idle for long after the first session so i wonder if the oil in the intake had seeped somewhere and then got burnt off on restarting the car.
Any ideas?
David
intake to MAF
Any ideas?
David
