You're unlikely to manufacture something as complex as a dual plenum IM veery well without proper design and simulation beforehand. Will just be a big waste of time and money if it's not designed properly.
well folks.... after my episode with the 86 zermatt car from NC with the paint issues and whatnot, and then my issue with not being able to stop for blazers in front of me, i decided to console myself with buying the car i originally wanted before going to NC.... a very clean, very nice 4kq, a...
To even begin to properly simulate flow through an intake manifold on a flowbench you are going to need a tad more than a couple of fans. I struggle to get much more than a 10" pressure drop on a good flowing intake manifold running 8 x 1200watt vacuum motors.
As for achieving the correct sort of flow straighteners only way is to design it on a 3D simulator. Even then it is still not 100% as inreal life you can easily exceed the speed of sound through the transitions causing sonic boom shockwaves which will throw a big spanner in the works. Unless building a low boost setup or small turbo setup I personally would stick with the big taper plenumb concept. Lot easier to get even flow distribution for the novice so long the TB doesn't point directly at any given runner.
I'll only actually need one fan, we have lots of three phase industrial fans at work with motors up to and over 10kw and i wanted to run it on an inverter or just fit a damper because i think the fans we have may be too big. Also i was going blow the air into the TB and down the runners, not suck it through.
My problem is i dont have room for a large taperd plenum and therefore my TB does point at one runner in piticular.
All the dual plenums on the market are built for FMIC applications and i even doubt they would fit under the bonnet.
Originally posted by quattro
Whay kind of flow meters were you thinking of using?
To start with i was thinking of using the little ones you get to balance a car running ITB's but i think the best solution will be 5 manometers all coming back to the same board for easy reference.
Yes this would be measuring pressure not flow but i think it would work.
Failing that you could put a fan from each runner and measure the voltage, more voltage = more flow.
Or all the above, the more information the better.
Originally posted by andy10v
derracuda on motorgeek made his own, more pictures in his project thread.
Thanks i was looking for that thread, i like the different approach he took.
