Hi! I've almost pulled most of my hair out by now to find this problem.
I'm running a GT3071R with all the extras and the first maf didnt last long before one of the threads got torn off... The car ran fine as long as i didnt go into "boost-mode"
Changed the maf and all good. then after about 700 km the car started to act up quite badly. No respons on less then half throttle and stalling and idling like crazy (400-1500rpm) took the maf of to check the threads and all are fine but the car barely starts and stalls every 50 meter when driving. When i disconnect the maf i get the same result as when the other maf lost a thread, smoothily running as long as you dont go into boost. So on with a new MAF again but still the same problem... car wont run with maf plugged in.
No fault codes to find on Vagcom
Anybody got any ideas?
Can you translate?
