air intake pipes s2 3b
  • Erikb
    • Jul 2004
    • 648
    From the moment when I bought the car ,the air pipe which run from the headlight to the air filter wasn’t fitted. Now all the air is sucked threw the big hole, in the air filter, where normally the pipe is fitted. The air is sucked right next to the turbo, not good for the performance I guess. And maybe also the reason why the car makes a more heavy noise in higher revs,4500 to 6000 revs. I wanted to order those parts, I was wondering if someone has the parts number or maybe a picture of the parts which I need.
    Thank you in advance ,
    Erik de Bruijn
    Getting everything sorted out for my 5++ hp project
  • Erikb
    • Jul 2004
    • 648
    Anybody an idea?
    • s2avant
      • 2426
      Do you mean number 18 in the picture?
      If so, the part number is: 895 129 627
      The price is a whopping £45.04+VAT over here!!!
      Ben
      • audiman
        • 4827
        I threw all my bits away. ******
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
        • Stick Insect
          • Dec 2003
          • 2338
          Ben
          Ben, reading Erik's post it may be the pipe that goes onto no.18.
          David
          • audiman
            • 4827
            There isnt one David. It fits into no.19 So the it picks up cold air from behind the headlamp, somehow?
            Audi UR Quattro
            • s2avant
              • 2426
              From what I can tell Nº 18 connects to Nº 19. The only 3B airbox I've looked at is Beeties though and that was at Billing so I was half baked
              Ben
              • Erikb
                • Jul 2004
                • 648
                Sorry for the late response. But that is exactly what I mean, thank you S2avant . I dont have the parts number 18,19 etc. Do you think I can just order these parts?
                • audiman
                  • 4827
                  Yeah you can order just those bits, but they are very expensive!!
                  Audi UR Quattro
                  • Erikb
                    • Jul 2004
                    • 648
                    Do you know a better solution, buying a open air filter maybe. Only this will maybe cause problems with the oil which will stick to the maf sensor.
                      I just took the 3b box off mine, I'll try and find the parts for you.
                      • martinjs
                        • 3205
                        get an ITG one, the oil they use isnt as thick as the stuff K+N use, so shouldnt be such a problem.
                          Actually I need the no 19 style part but for an ABY airbox.. Not sure what it looks like though.
                          • audiman
                            • 4827
                            I have been running a K and N for ages now. Also with the breather problem its dumping oil onto the MAF wire, causing absolutely no probs what so ever. I dont think that oil filter will cause any running problems. I never clean my MAF and it works perfectly.
                            Audi UR Quattro
                            • s2carlo
                              • 252
                              Hi Erik,
                              I am now running an open air K&N but am thinking of going back to my original Airbox (with some mods) and open air K&N.
                              If you are interested you could buy my open air configuration (complete with 180 deg turn)
                              Let me know by PM.
                              Carlo
                              No power, no glory!
                              S4 Avant, 2003, K&N-filter, 18", RNS-E, enough audio
