Exhaust Flexy Sections?
    The Flexy section at the bottom of my 034 downpipe is leaking really badly. Its welded to the downpipe so not an easy fix. Do I really need a flex section here? Is it there because its a fabricated tubular DP? Can I have the flexy fitted with a pair of V bands so it can be replaced without removing the DP? Or maybe better to have it fitted to the centre section? Does anyone know a place in Surrey/ Sussex border area that can do the work for me? I'll probably take this opportunity to change the rear box for a bigger one anyway.
  • jade
    • Jan 2005
    • 1811
    • Home: New Zealand Current: Spain
    Well I received my 034 down pipe 2 years back, I fitted it and found it leaked I had to remove and weld the inside part close to the vband clamp been fine since
    RS 2 580HP
      The leak is coming through the braided part so I'm pretty sure the flex is broken inside that, I'll have to take it off and inspect.
      • gnutz2
        • Aug 2006
        • 928
        The ONLY S2 Golf!
        http://www.s2forum.com/forum/showthread.php?t=19402
        10.42@138mph
        https://m.youtube.com/watch?v=0wnkkOfFpXg
