034MS Exhaust system.
  • WidowmakerS2
    • Oct 2007
    • 354
    • Current: Norway
    Anyone tried 034's exhaust?
    If at first you don't succeed, destroy all evidence that you tried.
    -CQ 3b "S2".
  • Bart76
    • Apr 2007
    • 117
    I have one, but did not try it yet..
      For the Coupe? Newsh has one on his car if you review his Coupe thread, it was up for sale IIRC
      • nesshead6
        • Apr 2009
        • 598
        I have it (for coupe), sounds amazing! It is pretty loud though so not to everyones tastes.. You need to make a bracket to help support where the exhaust goes over the rear driveshaft but other than that mine was a pretty good fit.
          Still on my car, the small silencer option which is what I ended up with by mistake when the website didn't accept my order the first time is effin loud, I added a centre box. Workmanship and welding is superb, fitting took a bit of fiddling.. The flexy at the bottom of the DP has started leaking so I'm looking at doing some work on it soon and changing to a bigger back box.
          • WidowmakerS2
            • Oct 2007
            • 354
            • Current: Norway
            Bought and mounted together with a 3 inch DP.
            LOUD allright. Will need to get a centre box in to make it drivable.
            But as newsh said; welds are great. I had no problems with fitting.
            -CQ 3b "S2".
            • Acidburn
              • 13459
              If this was for a s2 then sounds like they've got the downpipe issue's sorted.
              there was a few people who complained at the fitment as the downpipe was made for a urs4/6 apparently.
