3B fuel rail on an AAN intake manifold?
  • andy10v
    • 5996
    Will a 3B fuel rail/fpr fit on an AAN intake manifold? I have read that you can't fit an AAN/ABY fuel rail on a 3B manifold as the AAN/ABY fpr fouls the 3b intake manifold, just wondering it it works the other way?
    Sold ABY-stock
  • mrtat2k9
    • Jan 2009
    • 659
    ann is different to aby and aby is different to 3b. i made the mistake in thinking aby and aan are the same but they arnt. 3b will fit on a aby thow
    • andy10v
      • 5996
      Cheers for that, one step eliminated,
      Anybody tried a 3b on an aby though.
      Or a way to get a 3 bar fpr on an AAN setup?
      Sold ABY-stock
      • mrtat2k9
        • Jan 2009
        • 659
        3b will bolt to a aby with out problems
          Had my 3B rail and (7A) FPR on an RS2 IM so no probs for ABY, you'll need to make a bracket to support the FPR though, it's now fitted to the Wagner IM. AAN rail is different, bolts down differently I think,
            the 7A bracket to hold the FPR bolts onto 2 of the inlet manifold bolts, not sure if that's any different to the 3B but might be worth a look
            • JariP
              • 193
              You can buy 3bar FPR that will fit aby/adu and aan fuelrails, try part number 037 133 035 C. It's a FPR for mk3 golf or something like that, very common part.
              • andy10v
                • 5996
                Thanks, that opens up some options.
                Sold ABY-stock
                • ian4455
                  • Nov 2010
                  • 787
                  Can you fit a aby fuel rail to a 3b manifold ?
