New IC
  • audiman
    • 4827
    It must put the ECU into limp home mode or something i guess?? And just uses WG spring to control boost, might be why it was popping flames and running hot?? WG was set to about 1.5bar so it may have been overfuelling?? **** knows.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • SteveH
      • 4460
      Mik, I'll have to test it this weekend. It's under heavy load at higher RPMs
      I don't think it does it everytime I nail it. More noticeable when hot and the day ends with a 'Y'
      Originally posted by Mihnea
      Steve, what RPMs and what boost levels are you running when it's doing that pulsing sound? I would think it could be that, although the RS2 turbo can run ****loads of boost in an RS2 or an ABY (Sal running 32 psi for instance) without doing that sort of sh*t....
      So, young Thomas, your turbo actually sounds better when the lambda is connected rather than when it's disconnected? **** me if I know why that is so...
      91 Modded 3B
      14 A6 Avant Black Edition
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        #63
        Back to Doug's IC Project
        How's the project progressing Doug?
        It must be well on the way with all those parts for sale.
        Any more pictures?
        SS
        • Doug_RS2
          • 3847
          #64
          It is a LOT of work getting everyhting sorted to fit the AAN inlet manifold. I am hoping to get the IC and inlet manifold on the car this weekend. I'll have some pictures then.
          The PS pump is a pain - but I have new brackets made, a differnt pulley and belt, so that can be fitted and not foul the inlet manifold.
          • Sweeper
            • 1317
            • Country: Latvia
            #65
            I've just maid a replica of DahlBack IM . Hope it will work.
            A friend of mine waits for cargo from USA of
            600x300x75mm 20pcs
            580x300x63mm 10pcs
            Intercoolers for dirt cheap. Too bad it will arrive in 2 month , but the price will be great , if there will be anything spare left i will put them here for sale if anybody want one.
            Vadim.
            • SteveH
              • 4460
              Sweeper, any pics of your 'replica' manifold?
              BTW..the exh manifold has arrived
              91 Modded 3B
              • Sweeper
                • 1317
                • Country: Latvia
                #67
                Steve , will ned to attach throttle cable holder and fw nuts and bits , then will show you. In about 2 weeks , too busy lately.
                Great to know about exh. manifold.
                Vadim.
                • Billman
                  • 4129
                  #68
                  Someone sells these IC ??? Can someone use them with the stock RS2 IM and later change it to Wagner type IM ???
                  Greetings
                  Go Holset or Go RS4
