It must put the ECU into limp home mode or something i guess?? And just uses WG spring to control boost, might be why it was popping flames and running hot?? WG was set to about 1.5bar so it may have been overfuelling?? **** knows.
New IC
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm -
Mik, I'll have to test it this weekend. It's under heavy load at higher RPMs
I don't think it does it everytime I nail it. More noticeable when hot and the day ends with a 'Y'
Originally posted by MihneaSteve, what RPMs and what boost levels are you running when it's doing that pulsing sound? I would think it could be that, although the RS2 turbo can run ****loads of boost in an RS2 or an ABY (Sal running 32 psi for instance) without doing that sort of sh*t....
So, young Thomas, your turbo actually sounds better when the lambda is connected rather than when it's disconnected? **** me if I know why that is so...91 Modded 3B
14 A6 Avant Black EditionComment
Back to Doug's IC Project
How's the project progressing Doug?
It must be well on the way with all those parts for sale.
Any more pictures?
SSComment
It is a LOT of work getting everyhting sorted to fit the AAN inlet manifold. I am hoping to get the IC and inlet manifold on the car this weekend. I'll have some pictures then.
The PS pump is a pain - but I have new brackets made, a differnt pulley and belt, so that can be fitted and not foul the inlet manifold.S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
I've just maid a replica of DahlBack IM
. Hope it will work.
A friend of mine waits for cargo from USA of
600x300x75mm 20pcs
580x300x63mm 10pcs
Intercoolers for dirt cheap. Too bad it will arrive in 2 month
, but the price will be great , if there will be anything spare left i will put them here for sale if anybody want one.
Vadim.
New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !Comment
Steve , will ned to attach throttle cable holder and fw nuts and bits , then will show you. In about 2 weeks , too busy lately.
Great to know about exh. manifold.Vadim.
