Air Filter for 100mm turbo inlet ??
  • Air Filter for 100mm turbo inlet ??
    Can anyone recommend an air filter for 100mm turbo inlet dia?
    Hks bmc f1 filter, aem, kn
    A depends on space available
      does anyone have mad experiences with the different solutions? I plan to use the K&N41-1400, because i guess it will give the best flow in combination with the cleaning effect. But with 46cm length it is surely a task to find a proper pace for that monster.
        Got one of these if you need to relocate the filter
        http://www.034motorsport.com/engine-...e-p-18577.html
        RS 2 580HP
          Thanks I've seen one of those on here for sale, i was hoping to go for a filter that will go straight onto the 100mm inlet. Not sure about exhaust temperatures creating warm air though !
            That thing is rubbish, I bought one. It's only about 2" just before the turn and then has a flare to the 4"
            It tapers in size from the MAF outlet all the way to the bottom, turns then flares to a 4"
            It is highly restrictive and I had to remove it as it was strangling my 3076r
              Do you have a MAF? as you can't do that with a MAF setup.
              Look at my thread about filter setups for ideas
                What about moving the maf to the pressure side?
                Sold ABY-stock
                  *sits back and awaits prj to beat you with a big stick*
                  In all honestly it depends on who is mapping it and what they advise
                    I won't be using a MAF with my set-up.
