the one I'm looking at is a different supplier....fingers crossed not a rogue one
Beware of eBay MAF's
Don't know who the OP is talking about in this thread but this ebay seller sells poor quality ones too -- http://stores.ebay.co.uk/theairflowm...=p4634.c0.m322Audi S2 Coupe 1995
VW Passat GL5 (hatch) 1986
Carrera Subway 8Comment
You can get those poor quality ones from almost every spare part shop, but they usually also sells geniune Bosch, Pierburg etc. ones, of course at a different price. Always use OE MAF's or the same brand as orginal.
BMW 740iA e38 - ProjectComment
i bought a maf off ebay for my neighbours taxi a while back now, at the time they were £30, it came and inside it where the hot wire or whatever its called is on the original was a resistor in its place, didnt work and they sent another 2 before finally refunding me.. and then they doubled in price lolComment
MAFs
....or you could buy one of mine
Both have been working fine.
I hear what Dmitri says and I've put a new RS2 MAF but to be honest, I noticed the best improvement when I cleaned my original MAF in IPA.
2001 996 C4 - Being renovated
1994 ABY Coupe - "Das Smaragd RS2+ Coupe" - Sold
As said, only buy new genuine Bosch MAFs.
That goes for anything else VAG too. I'm getting pissed off with diagnosing duff MAFs for friends, only for them to get a cheap replacement, then complain the problem still exists. They seem to doubt me when I get VCDS on it again and tell them, "Yep. You still need a new MAF."SSComment
Same with BMW's too. Have diagnosed too much of them with trouble with second hand MAF's.As said, only buy new genuine Bosch MAFs.
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
Useless, they go out of calibration by themselves.
Any >10 year old MAF is out of calibration and the only thing keeping the car running half-decently is O2 feedback.
Nearly all second hand MAF's are junk, unless they have been tested with VCDS and the values match.
Group 000, 2nd value, 22-24 for ABY ECU, 18-20 for ADU or RS2'd ECU, on hot idle with no vacuum leaks.
Anything higher and it's junk, plain and simple.Comment
Completly agree.Useless, they go out of calibration by themselves.
The RS2 MAF fitted to my 3B Is still within range,(just) checked with VDCS.
However, I don't trust it and will be fitting a brand new unit regardless prior to remapping.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
