MAF to Turbo Hose Size
  • bikerjim
    • Feb 2008
    • 1028
    I'm hoping someone might be able to measure a MAF to Turbo intake hose for me. I'm just after the internal diameter of both ends please. :thumb:
  • prj
    • Mar 2010
    • 6308
    Off the top of my head - MAF is 80mm and turbo inlet is 70mm.
    • bikerjim
      • Feb 2008
      • 1028
      Ahh that sounds good to me, can anyone confirm this?
      • spink
        • 4382
        turbo inlet are 50mm I think
        • prj
          • Mar 2010
          • 6308
          No. Size of the inducer is around that, not the outside diameter.
          • Torben.E.
            • Feb 2010
            • 8
            • Country: Denmark
            Stock AAN turbo is 56 mm if that helps
              MAF is 80mm stock turbo is 57mm or 2.25 Inch
              • bikerjim
                • Feb 2008
                • 1028
                Awesome, thanks chaps
                • prj
                  • Mar 2010
                  • 6308
                  Ah right, now I know where I have the 70mm from.
                  That's what you need to install a K26/K27
                  Stock is indeed close to 60mm (57mm) as Jamo pointed out.
                  • sam80quattro
                    • Oct 2006
                    • 1496
                    is this for the t28 jim? does the airbox fit along side it?? be nice to know
                    • bikerjim
                      • Feb 2008
                      • 1028
                      It certainly is sam. Been madly collecting parts for this weekend. Hoping to get it all on.
                      the dimensions for the inlet and outlet of the hose seem good so hopefully it wont be too far off. I have no idea if the airbox will fit. Im hoping it will, but if not I will fab something up I think. I'll try take loads of pics for the thread but cant promise
                      • |Maku|
                        • Apr 2005
                        • 248
                        • Home: Estonia
                        Does any of the aftermarket companys offer turbo inlet hose for 3B/ABY/ADU that has 3" turbo inlet? I mean specially for 3B/ABY/ADU because they have bypass on the right side of the hose but S4/S6 have it stright.
                        And one more thing, is there a turbo inlet hose for bigger bypass or for two stock size bypasses?
