Running out of ideas!
I noticed that Greg S was testing his ISV and said the following:
I was trying to check the voltage on the ISV when engine running and varies with throttle opening between 5.2v and 5.8v which finger in the air is probably OK for approx 40 to 60% duty cycle.
So perhaps you could do the same with the MM set to volts on the the two pins of the ISV. If we get a voltage then at least we know something is happening. We know we have power, but despite the resting we have not really verified that the ISV is being controlled. Try that and post the result.
Hope it died before you did what I suggested!
