Since I replaced my rebuilt engine in my rs2'ed 3b coupe,I have had issues with it,one of which is the undrivability at low revs,its jerky,and the throttle is not smooth.I have done the usual and cleaned the ISV,changed the TPS,checked for vacume leaks and changed all the pipes,but it was still the same,idle at 1200 and jerky,boost osilating after bar.
The other thing is the boom from the 3inch exhaust when running at low revs has been unbairable,to the point of thinking of replaceing it.
But hears the strange thing,I had one more go at ajusting the throttle as Jon441 noticed that the arm was loose,this made a big differance in the drivability of the car,and a bit of an inprovment in the way the car boosts,but most of all the boom from the exhaust has gone.
I have no idea why this change in the exhaust should happened,or what was causing the vibration and boom,before it was realy bad and te car seemed to be holding back till you hit the gas.
