Good damn this tubular manifold
  • Mihnea
    • 1288
    Yup, I think it should work too, the only thing that I'm worried about is reversed airflow on throttle lift-off but apart from that, if it only takes minor adjustments to the chip, we should be ok IMHO...
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
    • audiman
      • 4827
      I may be able to do it the correct way! There may just be enough clearance if i can get a 180 deg, samco hose!! I may make it in SS.
      If i did put in the boost hose after the IC, where do you put the DV??? Where do you put the connections for it??
      Thanks for the help so far guys, keep the ideas coming.
      Tom C - www.rcmr.co.uk
      Audi UR Quattro
      Audi 100 C3 2.0 5 cyl 115ps
      Audi B5 RS4 645ps 911nm
      • Mihnea
        • 1288
        Tom, in case you have to, just chop the back of the fender off, this has been done already several times, the MTM RSR is using a fender-mounted carbon airbox, so why not??? IMHO do the 180 degree hose in SS, not just hose, that way if it ever rubs against anything, it won't wear out...
        M.
        www.MRCTuning.com
        info@MRCTuning.com
        Workshop Directions
        • audiman
          • 4827
          Mmmmm, dont really want to cut the inner wing out if i can help it. It should be possible, at the moment i have the MAF and filter sticking out the headlmap hole and i bodged some exhaust on it just to fire it up and check for water/oil leaks!! Those speedflow hoses are the dogs danglies.
          Audi UR Quattro
          • Mark Halligan
            • 2001
            Yes indeedy they are, its begining to look a bit 'bling' though Tom, I thought you liked it rough and ready
            Its looking good, if you do it with the 180degree pipe/hose will you wrap your new DP to cut down on underbonnet heat getting to the filter?
            Mark - Modded
            • audiman
              • 4827
              I may do, but will just make a heatsheild up for now! I cant afford to spend any more money. It was looking like i was gonna have to change ECU system yesterday, but i think i can get around this problem now.
              I hope
              Audi UR Quattro
              • Mark Halligan
                • 2001
                Now that would have been expensive what were you going to use....Motec?
                Mark - Modded
                • audiman
                  • 4827
                  Haltech or EFI034 system, i am still very tempted by one of these. That may have to wait until next year!
                  Audi UR Quattro
                  • Crawford_S2
                    • 1555
                    #24
                    Could you do something like this, with some tubing and a TIG. Think theres room in front of your mashed oil cooler
                    Ragusa Coupe gone!
                    • audiman
                      • 4827
                      Er, do you have that file in picture format?? I dont have MS Word on this PC
                      Audi UR Quattro
                      • Crawford_S2
                        • 1555
                        #26
                        Em, will try that again.
                        Ragusa Coupe gone!
                        • Crawford_S2
                          • 1555
                          #27
                          Try this link www.swgmotorsport.com
                          Ragusa Coupe gone!
                          • Lee
                            • 1512
                            Here you go dude. Perfect for sucking up water!!
                            Designun Limited....
                            • audiman
                              • 4827
                              LOL, ****** that
                              Audi UR Quattro
                              • Lee
                                • 1512
                                Didtch the aircon mate! It might not give you any more room but you know it makes sense. LOL!
