RS4 MAF Modification
  • Ross
    • Aug 2005
    • 3399
    Sounds painful
    So the element and electrical connector is one piece you buy from Bosch, and a simple swap into the MAF housing by the looks of things. Hmmmm, I looked into a batch of 10 housings, they want 250 bucks shipping, anyone off th china any time soon
    • prj
      • Mar 2010
      • 6308
      Originally posted by AndyP
      Is this the B5 RS4 MAF you're talking about using, part number 0280218067?
      Yeah, but get the exchange version 0 986 something.
      • europeanme
        • Oct 2005
        • 3817
        0986280219
        • AndyP
          • 6049
          Originally posted by europeanme
          I was looking at that one, never quite sure that the stuff you get off Ebay is genuine Bosch though. I've been quoted £130 for a new one ( not the exchange one ) today from a real Bosch dealer.
          • europeanme
            • Oct 2005
            • 3817
            wow, thats good...most places I checked couldn't get one for at least 2 months and it was over £170...
              Originally posted by Ross
              Sounds painful
              I've got a mate who's back and forth to China all the time
              • prj
                • Mar 2010
                • 6308
                You don't need the electrical connector, I got like 6 of them.
                As I have said before, I'll take care of all the electronics work. You wouldn't know where to fit what anyway
                The element from Bosch... I need to find the exact part number for the sensor.
                Also, what AndyP quoted is more in line with what it should cost.
                • SteveH
                  • 4460
                  What did Sonic go for in the end. The full RS4 Maf in it's large 87mm housing or another smaller housing with an RS4 element?
                  I'm attempting to make up a new inlet pipe and need to ensure I get the right size silicone joiners.
                  91 Modded 3B
                  14 A6 Avant Black Edition
                  • prj
                    • Mar 2010
                    • 6308
                    Full MAF, and he got a custom silicone maf-turbo hose made up, so it all fits nicely.
                    The RS4 MAF actually fits into the stock airbox if you mod the airbox somewhat.
                    • Sonic
                      • Jul 2006
                      • 5514
                      #70
                      Full rs4 maf directly into the rs2 airbox which was ground down a few mm to ensure a perfect fit. The maf is sealed into the airbox to ensure there are no leaks, and then finished off with a roose motorsport hose which was made for the job
                      Dmitri then wired in a new plug and did the necessary ECU mods to work.
                      S2Forum.com Administrator
                      • Rocco
                        • Aug 2007
                        • 6393
                        • Country: Spain
                        #71
                        and is good enough the RS2 airbox with +450Hp?
                        because in the past i sold my RS2 airbox because i had to fi a RS4 Maf
                        • SteveH
                          • 4460
                          The Roose hose sounds like the way to go, however was it made for the ABY pipe locations or it it just a straight through pipe from the turbo inlet to Maf housing? I can see my original Maf hose has a takeoff for the WGFV, the BOV return and the Crankcase breather hose inlet.
                          91 Modded 3B
                          • prj
                            • Mar 2010
                            • 6308
                            The Roose hose sounds like the way to go, however was it made for the ABY pipe locations or it it just a straight through pipe from the turbo inlet to Maf housing? I can see my original Maf hose has a takeoff for the WGFV, he BOV return and the Crankcase breather hose inlet.
                            It has all those too.
                            • SteveH
                              • 4460
                              It looks like my RS4 Maf has failed. Does anyone have the Bosch number for the sensor insert?? If I can get the sensor, I'm hoping it will be a lot cheaper than the whole Maf.
                              91 Modded 3B
                              • blackS2
                                • Apr 2010
                                • 455
                                F00C 2G2 047
                                [__]=oooo=[__]
