AAN Inlet Manifold on 3b
  • martinjs
    • 3205
    Now that ive fitted this big i/c i now need a reversed inlet manifold really, to get rid of quite a lot of pipework. So i decided to have a go at modding an AAN inlet manifold like mark and doug have done.
    Ive been doing it at work, lots of equipment to use i just dont have a decent tool collection to manage it at home.
    Its pretty much done now, so heres a few pics of how i did it. (some haven't come out too well)
    Firstly, chopped the side off with a waterjet machine lol,
  • martinjs
    • 3205
    Took about 5 mins saved lots of time
    • martinjs
      • 3205
      I dont have much room (if any) to move the rad back, so at this point decided to do a bit of 're-engineering' to it. Chopped off part of the front, so i can mount the throttle housing further forward.
      Access tubes removed and holes welded up.
      • martinjs
        • 3205
        Rebuilt section, now throttle body wont have to be tilted down so much at the front, so should clear rad. Thats the theory anyway.
        I want a tig welder.
        • martinjs
          • 3205
          • martinjs
            • 3205
            Thats pretty much it. Got a couple more things to do, bracket for throttle cable to put on etc.
            • martinjs
              • 3205
              • martinjs
                • 3205
                • martinjs
                  • 3205
                  • jubjub
                    • Nov 2003
                    • 1239
                    Looking good You got any jobs going at your place
                      Looks brilliant Martin!
                      • martinjs
                        • 3205
                        Ive beadblasted it, and will get it powdercoated silver.
                        I reckon about 6 hours work to get to this stage.
                        Needed the car for work too, so it was a bit of trial and error getting everything in the right place.
                        Will it fit? fook knows.
                        Will it leak? better not or its getting smashed up.
                        martin
                        • martinjs
                          • 3205
                          lol, you can have mine
                            Excellent work!!!!
                            Can i ask are will that affect the equality of flow air between the 5 cylinder inlets?
                            • martinjs
                              • 3205
                              Dunno mate, in the stock AAN position air flow points to cylinders 4+5 as you can see in the second pic, now it points at all cylinders albeit right next to no 1, maybe the proper engineers on the forum could advise.
