Up until recently I had no idea that the RS2 exhaust manifold was prone to cracking. Since inspecting mine a have a few small hairline cracks and I'm considering removing it for repair.
The dilema is that even after soaking in penetrating oil, there are several nuts which seem VERY tight, whereas some were actually loose?
1. What is the best method of removal re. the VERY tight nuts?
2. Is the EM relatively easy to weld?
3. Should I throw it in the bin and get a new one and if so which type - using RS2 turbo.
Thanks in advance.
Thanks in advance.
) from work as the minimum order price would make you **** the bed.
