Spicing an Audi RS2
  • bartolomeus
    • Jan 2009
    • 1475
    • Country: Romania
    Originally posted by pedros_RS2
    Isn’t he from Finland or from the neighbourhood. How can I remap it from Portugal?
    And I insist – isn’t remapping dangerous for an old car?
    Not from Finland.
    • pedros_RS2
      • Nov 2010
      • 24
      • Country: Portugal
      Originally posted by bartolomeus
      Estonia… not even close.
      Being from Portugal, can this remap be done at this distance? Chip?
      • pasbogdan
        • Sep 2009
        • 1160
        • Country: Romania
        Yes,chip.And another map sensor.Can be installed by yourself or ecu send.Or if you want something custom for your needs he use to get and map it live.It can be him(lots of 2.2 20vt users worked with him) or there are a lot of others.But take care at what you are buying.Ask for afr target,boost vs rpm,knock function active.Timing and other things i guess nobody will tell you(you will see that with vagcom).But the main ones should be explained.If seller does not know main things tell him to put his chips in his ***.Or under his balls with pins facing up.
        Do not listen tuners what ask you for another wg spring or fpr.You do not need it at this power level.You will need wideband afr.
        This is the cheap way to get a little more power.S1 sound?Would you like when running to hit a wall and after that to be asked to run again and to hit another wall and again and again?Spectators will like that,but not you.And not your turbine...
        Regards,
        Nice car!
        • pedros_RS2
          • Nov 2010
          • 24
          • Country: Portugal
          Regards,
          Nice car!
          nice and honest post! thks
          • s2_wot
            • Aug 2006
            • 2178
            #20
            Great photo have you any more? Look how the front tyre is being ripped from the wheel. Brilliant.
            I think your best possible return on investment will be by chiptuning the car by an experienced person. Not something from ebay etc. For our cars the ecu needs some small modifications in the hands of an experienced electronics person. Do not throw an RS2 exhaust into the scrap heap for a claimed 10bhp increase, this would be crazy.
            Be aware that tuning the car you will be asking for higher boost levels. In doing so you may develop a boost leak from your air intake piping or other similar small problems. This might be fixed using a new pipe clamp or by replacing a complete boost pipe. Higher performance will require higher levels of attention to these smaller parts.
            Shane
            • pedros_RS2
              • Nov 2010
              • 24
              • Country: Portugal
              #21
              I can look for more pictures later, I have some… probably not spectacular as this but…
              The exhaust change is only to put it a little bit louder and not for the extra 10hp, but they are welcome.
              • pedros_RS2
                • Nov 2010
                • 24
                • Country: Portugal
                #22
                my baby girl!
                • quattrostyle
                  • Oct 2006
                  • 6229
                  Stunning
