Reverse manifold accelerator cable help ?
  • jsws3
    • Apr 2012
    • 1174
    Does anyone know what's the best accelerator cable to use on a Wagner reverse inlet manifold for a ur Quattro please as it's longer ect ect ?
  • terrybullwon
    • Mar 2006
    • 8782
    Bike cable
    Chef
    • nip
      • Apr 2006
      • 1786
      • Home: United Kingdom Current: Abu Dhabi
      John theres a place in tysley, before the bridge on the left , that does accelerator cables
      • SE_30
        • Apr 2010
        • 1114
        • Home: England Current: Israel
        John, have a word with Will, he's making one for mine, and could supply you with another.
        Stuart
        B2 90 quattro with boost
        • SteveH
          • 4460
          it's an easy job to do yourself. You can buy the inner cable, outer sheath and teflon liner. You can remove the old nipple on the throttle body end and reuse it.
          91 Modded 3B
          14 A6 Avant Black Edition
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            Fit the original cable, but chop the inner cable so you can fit the end to the throttle body. Then call the AA/RAC/WHY, and they should be able to fit a new length of inner cable FOC.
            A friendly local RAC man did mine, and I'm not even a member of the RAC. Top service.
            SS
            • europeanme
              • Oct 2005
              • 3817
              I've heard about people using scooter cables....and cannot go wrong with a bike cable....make sure its a good quality with teflon lining outer....
              • GazzaG60
                • 4133
                I bodged mine with a bit of brake line iirc. chop cable, insert brake line. crimp to hell. put it in the original sheath. worked a treat for couple of years.
                jobs a good'n
                • Nik0las
                  • 1345
                  • Country: Bulgaria
                  Golf 3 1.6 monoinjection!
                  • GazzaG60
                    • 4133
                    maybe for a car with the wheel on the wrong side.
                    I believe there are loads of cables usable on a left hooker.
                    • jade
                      • Jan 2005
                      • 1811
                      I have used bike cables and they have failed over time on my Furans set-up, normally where the cable turns
                      best way I found, is to use the inner of a old cable which has a lining on it which makes it more durable and join it with a short length of copper tube to achieve the right length. I then just use a length heat shrink to tidy it up
                      RS 2 580HP
                      • DJones
                        • Jun 2005
                        • 2020
                        I just used the original WR one.
                        • martinws
                          • Oct 2008
                          • 917
                          I used a urs4 cable on my homemade reverse inlet.
                          • jsws3
                            • Apr 2012
                            • 1174
                            Do you have a part number for it mate ?
                            • jsws3
                              • Apr 2012
                              • 1174
                              Daren do you have a part number for the wr cable ? Mate .
