0.7% will fail on CO in most european countries if the car ever had a cat fitted.
The requirements for a catted vehicle are:
CO < 0.5%
HC < 100
O2 < 1.0
Lambda: 0.97 to 1.03
MOT Emissions Failure after RS2 Spec
Without cats, CO should be in the 0.7% region, HC should be under 100 ppm. Need to get it on VAG com to see if anything is broken.Leave a comment:
The MAF's are identical regardless.
I don't know what the laws are like in Malta. But in most European countries there is no way in hell you are legally going to pass MOT without a catalytic converter on an ABY engined S2.Leave a comment:
Was the RS2 changes to your ecu done with s2 maf or rs2 maf in mind?Leave a comment:
I guess it depends on what the Malta equivalent of an MOT requires, in the UK any car made after 1992/3 needs to have a cat fitted to pass unless you have a 'friendly' garage.
As far as I'm aware there's no requirement to take you car back to a place that's fail it, all that matters is that is passes somewhere.Leave a comment:
You will fail MOT without a cat... even on standard S2. As said find a friendly garage or install sports cat.Leave a comment:
Any advice on this? No cats, new exhaust manifold as well, exhaust is definitely not blowing. Don't have any figures as these were not provided..
It is running a bit rich though as I am running a higher octane I presume than what is required. Would too high an octane cause an emissions failure? Any advice appreciated!
Tags: None
