Can they fail you without quantifying why? It's different for play in a suspension bush etc which is a matter of opinion and a visual inspection, but you'd think they'd have to give you the figures for this?
MOT Emissions Failure after RS2 Spec
Yep weird, looked for the emissions on the sheet but could not find anything..
1996 S2 ABY SilverComment
Not in N Ireland. If you fail on brake effort or imbalance on either service or secondary brake you get a full print out, plus headlight alignment. There is also a computerised shock test but having never failed on that one I cant say if they print that out or not.
Basically, you get the data proving why you failed.1996 Audi S6 Avant.
1994 80 TDI - Daily DriverComment
Went to the MOT garage our company uses and passed it but the emissions were way too high, did not get the readings but it is definitely something to do with the exhaust me thinks as it is pretty fubbared with all the scrapes and dents, sure it is leaking somewhere probably
At least that headache is over, now for the exhaust, anyone got a nice system for sale?
No it's because there is no cat. Except the cat the exhaust system itself ha no effect whatsoever on the emissions, its just a tube they travel through.
FWIW most testers in the UK won't even bother checking the emission on a a post '92 car without a cat fitted - it should be an immediate fail regardless.Panthero Coupé quattro 20vt
Imola B6 S4 AvantComment
