IC core question
  • Thuppu
    • 4115
    IC core question
    Got hold of a big intercooler that seems to be really good quality. What do think about the core, would it flow enough in a car solution if cutted in half? Or does the bars look too narrow? Core size would be 610x320x95mm + the end tanks.
    This IC is from a big Ingersol Rand screw compressor that has been feeding a big factory for years.
  • quattrostyle
    • Oct 2006
    • 6229
    Originally posted by Thuppu
    What do think about the core, would it flow enough in a car solution if cutted in half? ]
    Why not leave it as is, looks good to me
    That thing is huge
    • Thuppu
      • 4115
      Haha, good idea.
      • V6quattro
        • Sep 2008
        • 949
        haha perfect fit!
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          problems with your intake airtemp?
          TWINCHARGED power,zero lag
          AEM W/M injection
          • AndyP
            • 6049
            The question is, does the big factory know their intercooler is missing?!
            • A1QSHIP
              • Aug 2004
              • 975
              You could always do a roof mount.
              "Nulla tenaci invia est via"
              • Majorcina
                • Jun 2013
                • 1334
                • Country: Montenegro
                How it fits behind the bonnet
                • Thuppu
                  • 4115
                  Well, guys you know. I always have stupid ideas, something like moving the rad to the trunk and fit a IC that covers the whole front.
                  The main question is, does that core look good for a turbo application?
                  • my2000apb
                    • Jul 2010
                    • 637
                    can you get it flowbenched?
                    BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
                    DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
                      Originally posted by V6quattro
                      haha perfect fit!
                      • Thuppu
                        • 4115
                        So I did cut it open. Well, the rows are quite narrow, inside opening size is 3x80mm. If I would do a 320x610mm size IC, it would have 21 rows, flow area would be 50,4cm2(minus the cooling fins). If I would throw the radiator in the trunk, I could fit a 460x610mm IC, 30 rows, and area would be 72cm2. For reference a 3" pipe has a 41,8cm2 area.
                        Will it be a restrictor?
                          50cm2 but at 2.5 bar, or whatever boost you run. So maybe up to twice as much gas volume as your exhaust with minimal backpressure... I think it will be OK
