OE COil Pack Wiring Harness Dimensions
This is a sticky topic.
  • Rusty
    • 18953
    Following on from this thread.
    As I love all of you, I've measured the OE coil harness, so that anyone who wants to can build one and replace their knackered OE one.
    From my inspection, the wiring outside the cover is fine, so if you're on a budget, you can just reuse a portion of the old loom, the old plugs, rubbers etc.
    There are 2 wire colours that come from the coils, Black (B) and Yellow (Y). All dims are to the nearest 5cm.
    All yellows go to the white plugs and pin position is not important.
    I have included pin positions for the black wires on the brown and black plugs, which attach to the POSs.
    Treat the lengths as a guide rather than gospel and I would suggest soldering wires to the coils and then rebuilding the coil cover with all wires routed correctly before making your final cut. This will ensure they're spot on. If you are attaching to the OE plugs with short tails, make sure you stagger the connections to make the diameter of the wire as small as possible.
    Anyway, here's the dimensions I've measured:-
    All Coil Leads
    • Outside Diameter 2.3mm
    Coil 1
    • B - 100 cm
    • B - Brown Pin 1
    • Y - 80 cm
    Coil 2
    • B - 100 cm
    • B - Brown Pin 2
    • Y - 80 cm
    Coil 3
    • B - 85 cm
    • B - Brown Pin 3
    • Y - 60 cm
    Coil 4
    • B - 95 cm
    • B - Black Pin 1
    • Y - 55 cm
    Coil 5
    • B - 80 cm
    • B - Black Pin 2
    • Y - 40 cm
    Earth
    • 40 cm length
    • 6 mm diameter eyelets
    • Outside Diameter 4.4mm
    Protection outside of coil cover
    • B - 60 cm
    • Y - 30 cm
    Protection inside of coil cover
    • Whole length of the loom.
    • I suggest that the internal protection is extended past the cover clamp and then the wires grouped in to colours outside of the coil cover.
    • This will maximise protection of the wires and minimise the chances of the wires cracking where they are unprotected and shorting on the cover, which is what I think happened to mine (again).
    Total wire lengths
    • B ~ 4.6m
    • Y ~ 3.2m
  • Fat Audi 80
    • 10547
    Legend! This has to be on the cards for me one day soon....
    The Perfectionist
    • BorisShakhov
      • Feb 2009
      • 224
      • Country: Russian Federation
      • Rusty
        • 18953
        Hope it's of some help. It's still a fairly big job but at least the above should help.
        Totals added.
          Shock horror @ Rusty not referencing wire colours in German lol... B & Y just looks wrong - should be SW & GE to line up with OE colours !
          Seriously though - to add to this, the Bosch part numbers for anyone embarking on loom repairs - the POS/BIM connectors are as follows - I will annotate the Audi and AMP numbers on there when I get time -
          3-pin JPT (COIL side) Bosch 0 261 205 289-01
          4-pin JPT (ECU side) Bosch 0 261 205 351-01
          • A1QSHIP
            • Aug 2004
            • 975
            I have been working on European cars since 1976. & I have to translate the translations back to the way Bosch created it to read the diagrams. Thankful for my German studies in school.
            Chris
            "Nulla tenaci invia est via"
              Sadly the Audi wire colours and some other basic terms are about the only German language that I know !
              • Rusty
                • 18953
                My life's work is in ruins... can't please everyone
                  Don't feel bad... 99.99% will thank you for using B & Y ;-)
                  As an aside - I am cross posting to this thread which may tickle some interest - http://www.s2forum.com/forum/showthr...358#post818358
