I thought people used lambda spacers when decatting pre/post cat lambda setups to stop the ecu throwing a code, which would make me think if it alters the reading enough its not a good idea on a lambda sensor you are actually using.
Yeah as Andy says I'm pretty sure lambda sensors have to be mounted fairly vertically to read correctly and prevent condensation damage. The 120 does look like it could work.
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.
Actually after looking at the photo's again I don't think I'd want to use either, I can't see how the sensor is going to read accurately when not in the main stream of exhaust gasses.
1994 MTM RS2.
2000 B5 TQS.
That's what I was thinking, although the 120 deg one does have a bigger hole..
Maybe I'll just cut a hole in the bottom of the airbox, or take the DP off and add another boss in the right place, was just looking for a lazy option
