Iam running a wagner EM with the little adaptor from the four 8mm studs to the V band wastegate and iam having trouble sealing/keeping the studs and nuts tight.
I know there is no gasket and the steel on steel is what it relies on to seal but how do you keep it tight
thanks
mal
think they are steel exhaust type nuts, dont think loctite would handle the temp. Also should have added its running antilag not that it should change things to much. Just thought id see if its just me or if its common prob??
thanks
mal
The nuts iam using are locking , they have a locking last thread on them. Maybe the studs are poor qual and are streching with each heat cycle , ill try new studs and nuts and see what happens?? thought it might have been something that someone had fixed before, cant do anything until i get the close box back in anyway
thanks
mal
The manifold is flat but the adaptor is curved slightly maybe due to the welding when made, i thought that was how they are supposed to be as it would force some preload onto the joining faces. I can get it machined flat if thats what it should be??
thanks
mal
thanks
mal
