Wagner reverse inlet, throttle cable solution?
  • Colesy
    • Feb 2009
    • 2982
    I've read through I think all the threads about the reverse inlet setup but haven't found a definitive solution for the throttle cable on RHD.
    I know on LHD the URS4 throttle cable fits no problem.
    I have a URS4 cable but on my RHD it is about 2" too short, this is at full stretch.
    I've read a few solutions involving extending the cable but none that jump out at me as a great solution. Another option is to feed a longer aftermarket cable through the URS4 sheave but I didn't find any firm information as to which cable to get, the specs etc.
    So if anyone has any suggestions or details of what they have done please post up.
  • GazzaG60
    • 4133
    ive extended mine in both instances. I use some copper brake hose to extend. sounds bad but it works no problem.
    • Colesy
      • Feb 2009
      • 2982
      Cheers Gaz, I now have everything fitted after a long weekends work:
      Have the throttle cable tie wrapped the the moment! Will be getting something more permanant asap. A knarp or a cable clamp is apparently what the pro's use, so will hopefully have one of those in hand soon. Might try the copper pipe, I suppose it acts as a sort of crimp.
      • GazzaG60
        • 4133
        I cut the cable and run the copper pipe through some hosing. attach it to where the wagner isv bracket goes and run it straight down the edge of the manifold.
        • Colesy
          • Feb 2009
          • 2982
          Not sure I quite understand exactly what you mean, do you have a picture at all?
          • GazzaG60
            • 4133
            yes but not here.
            to describe I use as yours is buit from the tb ncable holder on the manifold I run the cable over the isv. its straight so its ideal for the copper pipe. the rest of the cable then runs around the back of the manifold rather than over it to the bulkhead.
            • sailaz
              • Oct 2009
              • 647
              • Country: United Nations
              .... I think this one should fit perfect
              EDIT: found here: http://www.s2forum.com/forum/showpos...1&postcount=14
              • GazzaG60
                • 4133
                my current cable is a 4 pot kjet cable. its not long enough either.
                • Colesy
                  • Feb 2009
                  • 2982
                  Cheers for the link, but that's the one I have. It fits perfectly on LHD but it's just a tad too short for RHD!
                  • GazzaG60
                    • 4133
                    to my knowledge all are too short. I was thinking a lhd 16v cable for a 6a engine. mine is a rhd 6a cable.
                    lhd 6a should put the cable full diagonal. cant be 100% though just a gut feeling.
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      I've said it before, but for my MTM/Dahlbäck manifold I used an original cable outer, but got a longer inner cable.
                      I also moved the retaining bracket further back, so that it could be routed around the back of the manifold more neatly. You can see the bolts sealing the original holes in the following photo.
                      SS
                        How did you fix the end pieces on Stu? Solder?
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          The end is fixed with a small grub screw.
                          SS
                          • Colesy
                            • Feb 2009
                            • 2982
                            Cheers for the reply, nice solution.
                            Looks like I might have to reroute the cable also as when I shut the bonnet it jams the cable!!
                            EDIT: It's the plastic bonnet trim that is jamming the throttle body so I have some cutting to do.
                            • GazzaG60
                              • 4133
                              yep on aby/newer bonnet it catches on the tb and or cable. on the older b3 bonnet it doesn't catch. I dinted with a panel hammer a small spot to stop the tb jamming on throttle.
                              my cablr runs similar to 4wheeldrifter but used the stock cable fitter to bolt to the dipstick tube and fits I the wagner holder. I used to run a network 2 u rack bracket on the s2 off the bulkhead to mount the cable to also.
