N71 Idle Speed Stabilization Valve (ISV or ISS Valve) Info
Originally posted by LeafBox
I'm referring to a MC2-engine, but I guess the same goes for all the 5-bangers with ISV... We all know it's usually just a troublemaker, so is it as easy as just plugging the hoses and raise the idle with the screw on the throttle body?
Not the same. If there is a computer and there are things like A/C you need and want a properly functioning N71 ISV. Removing it will create several issues, including engine stalling. But hey...it's your car.
N71 Idle Speed Stabilization Valve (ISV or ISS Valve) Info:
you can always try
i woud remove the isv and place a adjustable screw( like the ones they use on a gas system) between the 2 hoses from the isv
you can adjust idle by hot engine
but like dave says, probably you going to have problems with cold engine or at other times
TWINCHARGED power,zero lag
AEM W/M injection
