Here are some photo's from my set up. I really wanted the OE look rear muffler. I also wanted it to react immediately so the slow electric ones ware no good to my. And of-course it should absolutely not effect the performance. O and i also did want to keep my 3.5'' middle box.
So i modified the rear muffler a lot to get it all to fit. Its all controlled by vems. When i shift back and go past 3750rpm the valve opens immediately. I could not find a 3.5'' vacuum cut out so i used a 4'' china throttlebody.
After doing all this will i do it different the next time? Yes of course
I think i will use OE rear and middle muffler to get the noise down moor and place the 110mm cut-out where i have my 3.5'' muffler now.
0-200km/h 9sec
] but its to quite ,, so now ive decided to do something about it , going to fit a 10" alloy silencer only 1kg
the new exhaust flap device weighs 1.5 kg
but even with that fitted weve still saved 4kg [ which helps me sleep at night ,with my weight loosing obsession ] plus the car should at last sound more like a rally Quattro
