Phenolic gasket
  • Kiku
    • Aug 2010
    • 497
    Phenolic gasket
    Does anyone have experience with this type of product.
    http://www.ebay.co.uk/itm/Ansaugrohr...-/191788334093
  • DNA-S2
    • Sep 2012
    • 369
    I use this all the time on 90% of my engine builds...
    Highly recommended [emoji106]🏻
    Reduces intake temperature for 20+ Celsius which allows you to have more ignition timing!
    That price is cheap to
    Danny
    www.dnaautocare.co.uk
    • sailaz
      • Oct 2009
      • 647
      • Country: United Nations
      it needs standard gaskets from both sides ? ?
      • Thuppu
        • 4115
        Yes, but I don't think that will do much if you drive the car sometimes.
        • sailaz
          • Oct 2009
          • 647
          yes, sometimes, but to the limits
          • filip.krticka
            • Sep 2008
            • 170
            • Home: Czech Republic
            I have this feature installed in my car.
            It is ok when car is running. Once cars is switched off than whole intake manifold is being heated by radiant heat.
            If the cooling period is not long enough to cool whole engine, than there is a certain limitation of course.
            • orsum
              • May 2010
              • 1213
              • Home: United Kingdom Current: South Africa
              What is it made from?
                Phenolic
                • sailaz
                  • Oct 2009
                  • 647
                  I'm a bit confused ... Are you saying that after installing this phenolic gasket IM is getting more heated compared with a OEM gasket setup, when engine is switched off ?
                  • filip.krticka
                    • Sep 2008
                    • 170
                    No. I have tried to say that biggest benefit after morning start up. It will definitely keep IM cooler for a longer period of time. Phenolic gasket is good upgrade, IM is getting less heat out of cylinder head, no doubt. Miracles cannot be expected as rest of engine bay is hot as well.
                    • sailaz
                      • Oct 2009
                      • 647
                      Good ! Then everything is as supposed and designed to be !
                      • pilachgt
                        • Dec 2004
                        • 33
                        • Country: Poland
                        Is this solution much better than teflon gaskets?
                        Audi S2 Coupe - parts for sale
                        • Thuppu
                          • 4115
                          How much would the IM heat up the flowing air? I think only small benefit of this phenolic spacer may be reduced heat soak after you have turned hot engine off and start it soon again.
                          • A80Avant
                            • 10873
                            • Country: Greece
                            With the reverse inlet manifold the difference is significant even when stationary in traffic. I had mine without and then after fitting one it's a huge difference.
                            Perhaps that manifold has much thinner walls and heat gets transferred easier.
                            Then again if you keep the oem temp sensor you may not notice due to the 7C temp steps it takes
                            • Thuppu
                              • 4115
                              Perhaps there will be some advance in very slow traffic(heat soaking), but I just can't belive it will effect anything in spirited driving or WOT when the air flow in the intake is high.
                              Isn't the resolution with OEM IAT sensor 2C with newer Vems firmwares, and 1C with 1.8T sensor?
