The engine doesn't cut out just a violent jolt on boost.
Will a leaking exhaust flex cause any running issues
I have had a intermittent boost problem. It turned out the mfwt multiple function water temperature sensor needed replacing and the plug had see better days. Could not get a new wiring plug but I did discover the v6 coupe has the same plug and coz the plug is on the top the rubber cover doesn't fill up with crap . So the plug was in good shape. The plug can be taken apart cleaned and reused. You can unplug your mfwt then drive it. Fingers crossed its that. I seen that a lot of people have had trouble with this part before. Anyway hopefully you get to the bottom of your problem. Kindest regards Lynn.Comment
When Mihnea was live mapping my 3B the first time it would sometimes cut and throw a plume of smoke out the back, he diagnosed timing out so I checked it and had to move the dizzy a few degrees to line up the marks when flywheel was on the zero mark. It was fine after that.
I guess you've checked the WG diaphragm with a vac gauge?Comment
