WG removal
  • s2_southwest
    • Oct 2004
    • 823
    WG removal
    I assume that i can remove the whole wg assembly by removing the 4 nuts arrowed in red, without having to remove the wg cap etc arrowed in yellow in order to remove the whole wg. Any problems i should look out for?
    Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
  • sal_s2
    • 1291
    Yes, remove those 4 nuts and the 3 that attach to the downpipe and lift the whole thing up.
    Pretty straight forward, just be careful not to round the heads on the 12mm nuts
    • s2_southwest
      • Oct 2004
      • 823
      cheers sal, just need to remove it so i can get to replace the 4th nut that bolts the downpipe on that came loose
        You'll find that a banana shaped spanner is very useful for this little chore. Of course Audi list an official tool for this - you can get banana spanners from Machine Mart. BTDT
        Paul
        • s2_southwest
          • Oct 2004
          • 823
          that doesnt surprise me, i did it today anyway, just had to grind down a ring spanner that i had and it managed to fit into the cut out in the casting for the spanner to fit in.
          i guess making things easier without the need for special tools is a bit too much to ask for lol
