accelerator pedal
    • 12431
    I have done something similar. Ruff up the pedal plastic and the pedal and use some grip fill. Works a treat on mine
    • mickey_205
      • Jan 2005
      • 25
      i dont like to bodge things!!
      • Jas11n
        • 5067
        I had the pedal break off in my old coupe, dog ran out in front of me, I slammed the brakes and the accelerator pedal snapped off go figure.
        I didn't want to simplly just glue the thing on as I liked the springing action.
        I now know they aren't that expensive off Marty (£32.96 + the dreaded) but at that time I didn't know of vagparts, so I reattached it with a very small brass hinge. A small hole in the hinge took care of the spring bit sticking up so I also kept the springing action. Sorted.
        Lasted 3/4 years like that, then another 6 months until the guy who bought it off me murdered the car RIP
        Sorry about pic below, this is a scanned image of a an old film camera picture (remember those? ) and it took me an hour to find it .
        2001 Avus Silver B5 RS4.
        1995 S2 Coupe - sold (sniff)
        • Fat Audi 80
          • 10547
          I now know they are that expensive off Marty (£32.96 + the dreaded) but at that time I didn't know of vagparts, so I reattached it with a very small brass hinge. A small hole in the hinge took care of the spring bit sticking up so I also kept the springing action. Sorted.
          Hmmm, didn't think of putting a hinge back on it
          Good idea!
          I was working on the principle that if it broke again or I didn't like it, I would buy a new pedal anyway.
          The madness of it is, the hinge is a molded part of plastic that is BOUND to break eventually..... That was a poor piece of design by Audi IMO.
          The Perfectionist
            • 12431
            Personally i prefer it now it doesnt have the spring action. feels weird using a sprung one by comparison now
            • 91_S2
              • 612
              #21
              Nice
              Damn Doooood,
              I have been messing with that pedal for ages. Thanks for the info.
              R
              PS - Of course if it is not as easy as you say, I will hire 2 Mafia hitmen to put a horses head in your bed.
              • curlyks2
                • 1069
                Originally posted by Fat Audi 80
                1. Pick broken pedal off floor and scratch head
                Yup: just done that
                Just when I thought things were getting nicely sorted too. Oh well *sigh*.
                Ck.
                Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
                • Fat Audi 80
                  • 10547
                  Hee Hee - Annoying isn't it!
                  Mine is still on now after I glued it on 6 months ago. I will get around to buying a proper replacement as i would like the hinge part to work again.
                  However if you are not bothered about the hinge rough it up, whack some araldite on it and tie wrap it in place and its (nearly!) as good as new.
                  Cheers,
                  Steve.
                  The Perfectionist
                  • BRY
                    • 3755
                    #24
                    It's not OEM though is it??
                    • pixsaudisex2
                      • Sep 2004
                      • 3110
                      #25
                      pedal
                      well i used two cable ties and kept the spring action done it over a year ago and its still going fine i drilled two holes through the side of the pedal and two holes on the actual arm one either side of the metal rod that comes down i then put cable ties through did them up and you can only see them a little bit no ones ever noticed them and the pedal still works fine,,,
                      • Fat Audi 80
                        • 10547
                        Did somebody say something?
                        The Perfectionist
                        • tom
                          • Dec 2004
                          • 282
                          #27
                          there is a simple way to put a broken one on its place without spending any money and it will be still working correctly ( i mean rotate a bit as it shoud be )
                          all You need is akku drill and a piece of steel bar. i repeared one and it work perfectly for months now. will try to make some photos soon.
                          all You have to do is drill thru the side of the pedal and the arm in right place and use steel bar as a new axle to make the pedal rotating again. diameter shoud be about 3-4 mm. the stell bar must sit tight in its place so little hammer will help the operation. the only problem is the position of Your body while working. pain in the ***.
                          • LowerRag
                            • Oct 2007
                            • 64
                            • Home: United Kingdom
                            #28
                            just done this without the ruffing up, will ruff it up oif it falls off
                            or
                            drill 2 holes get 2 screws and relax
                              Smegging pedal has broken on my S2 today, how long has the epoxy method lasted for?
                              • pixsaudisex2
                                • Sep 2004
                                • 3110
                                #30
                                two cable ties jamo by far the best method i have done it on about five cars now no come backs and it works oem i tell ya if you are boared and round my way ill do it for you..
