They are selling 2 for £2.79 or 10 for £4.99 So not that much more or its even the same price as the little kit you bought!!!!!
Who wants Plasma Gauge faces form racing24de
Right ive blown all my bulbs in my switches and heater controls so ive taken the bulbs out and taken off the red plastic off the back of the heater controls so that will light up blue,also on the back of every button is a red bit of plastic that comes out,but now heres a bummer the headlight height variable resistor is red and i had it apart tday and its encased in red plactic,so might leave that red,also on my heated rear button the bulbs are soldered in place they dont push in,the rest are push in bulbs i will get pics tmorro on my dinner.next is to work out the elecy windows there comin apart tmorro too.1990 100 2.2 10vqt 82k miles(now dead)
1990 90 2.3 20v 166k miles
1988 90 2.0 10v 181k miles
oh and a polo for work.Comment
Ok, sounds good. Pics would we Great too. I have bought 100 15Amp fuses (£5
Ill send these out alongside the bulb kits, because every one is bound to blow a few
Ill email racing24de tomorrow to find out how they are getting on
Cheers..
Bo91 S2 coupé - RIP
98 S8 - Luxury bargeComment
ok, a tip for free (yes im drunk). turn the leds upside down, so the will emit light trough their A S S. if you turn them the "right way" the will "shine" way too much any the will be killing you eyes by night. if you do like i said the will be so easier to solder. put the resistor to the side, where the 3 pins are. there is a "wire" already there, change it with a resistor and you are in business.Audi Quattro WRComment
Emailed the Germans few days ago, Have not heard back from them yet.
If there is no reply by lunch time i might give them another call.
They have stared making the gauges though as i payed them the deposit and there last email confirmed that they would start the "production" processes.
Ill post me news when i know.
Cheers.
Bo91 S2 coupé - RIP
Ok.. Here is the first layout, It just came in form racing24de (Please note this is not the actual gauge faces!! Its just he layout form autocard or similar!)
P.S. I have this in a much bigger resolution but i cant post anything above 800dots
gauges.JPG91 S2 coupé - RIP
I am very please to also say the following:
email form Germans:
Hallo,
ich habe gerade die ersten Layouts bekommen, diese füge ich dieser Mail bei.
Die km/h Skala kann optional dazugeschaltet werden.
Schalterstellung1: Es leuchtet nur die Meilen Skala
Schalterstellung 2: Es leuchten Meilen und km/h Skala
MfG Racing24.de
This means:
Hello,
I have just received the first layouts, these are attached to this email.
The km/h markings can be optically adjusted.
Setting1: Only the MPH markings glow
Setting 2: Both the MPH and km/h
With friendly greetings Racing24.de..
Great news to me!!!
91 S2 coupé - RIP
oh yes
cant wait to have them in the carPearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim
& 2 bar! Comment
I found this also,Originally posted by AUDI9020VRight ive blown all my bulbs in my switches and heater controls so ive taken the bulbs out and taken off the red plastic off the back of the heater controls so that will light up blue,also on the back of every button is a red bit of plastic that comes out,but now heres a bummer the headlight height variable resistor is red and i had it apart tday and its encased in red plactic,so might leave that red,also on my heated rear button the bulbs are soldered in place they dont push in,the rest are push in bulbs i will get pics tmorro on my dinner.next is to work out the elecy windows there comin apart tmorro too.
The solution is quite simple.
Cut both the primary bulb connectors about 1 cm from the circuit board or just below the line where they clamp on the the bulb wires.
Then get one LED and turn it upside down. This will stop it from glowing to brightly.
However try to adjust it so that it has the same distance from the front of the switch as the other LEDs, Otherwise that switch will light up dimmer than the others. (I didnt do this as you can see in the image and will need to replace it with a new LED so that its closer to the cover of the switch.)
Next cut one of the wires on the LED, Cut the one that leads to the main section inside the LED. then attach the resistor (See image).
Then use some electrical tubing to cover the cables so that they don't short out. (Again see image.) Then ressemble and your done.
I am going to do the adjustable switches tonight, They need a bit of soldering as they will probably need to LED's to over power the red plastic.
Will pics pics later..
Cheers.
Bo
Sorry i forgot t add that you will need to drill out the inside of the switch where the LED is located, (This is only if the ones you are using are bigger than the bulb) Otherwise it will not fit. (This only takes about 1 minute.) You only need to drill the very bottom so that the chamber that holds the original bulb falls out.
Thanks.91 S2 coupé - RIP
