Make it STOP!
  • Ski
    • 2591
    Make it STOP!
    plz plz plz.. make it go away, its driving me crazy.. ive put up with it for over a year now, and now its worse due to stiff suspension.
    what Im talking about is that annoying squeek coming from the passenger seat.. when i put force onto it (pushing it back or forward) it stops.
    Ive tried wd 40, ive tried tape in areas where i think it squeeks but nothing. I dont even know where its coming from apart from "back" of the seat.
    anyone had this issue?
    ABY Coupe
    Get a cat to catch the mouse in the car
    • WabTheKing
      • May 2004
      • 2567
      install a "woman" on yor passenger seat and set to "thrust backwards and forwards"
      remember to keep eyes on the road at all time while driving tho
      • Ski
        • 2591
        If i get a woman in my passenger seat the squeek will be replaced with a moan.
        ABY Coupe
        • Sidspud
          • 1223
          • Home: Scotland Current: United Nations
          Originally posted by WabTheKing
          install a "woman" on your passenger seat
          That has to be the most expensive "fix" I've ever heard of!
          Ski - why not just remove the seat? Think of the weight you'd be saving as well.
          ex '93 Avant owner
          • urquattro-island
            • Mar 2006
            • 1915
            • Home: Norway Current: Iceland
            just
            get a dog by your side hell be your best friend and wont squeek
            japanischer industriabfall nein danke!!
            www.rackeltrim.se Icelandic Division
              • 12431
              try replacing the little plastic clips on the seat runners
              • Ski
                • 2591
                what plastic clips ? any pics/diagrams?
                ABY Coupe
                  • 12431
                  There was an article in total audi about tidying up tired UR's. The plastic clips are fitted onto the runners either side of the car in the rear footwell so that your seat can move back and forth smoothly without rubbing metal to metal
                  • Ski
                    • 2591
                    Thanx greg I will try some wd40 on em to see if it helps.
                    ABY Coupe
                    • volcano rs
                      • Jun 2005
                      • 2265
                      those plastic clips normally cause the seat to rock from side to side if broken or worn they dont normally squeak. its something inside of your seat that needs messing with .
                      • Stick Insect
                        • Dec 2003
                        • 2338
                        There is one at the front as well which is my favourite to cause this noise.
                        David
                        • urquattro-island
                          • Mar 2006
                          • 1915
                          sqeeking springs in the frame???
                            Turn the stereo up?
