Hi. Im in the process of re-trimming my door card panel inserts from jacquard to leather so that they'll finally match the rest of the interior!! Doing it myself as it should be a reasonably easy and inexpesnive job to do! I've got two spare foam panels to act as templates and on which to mount the leather, (currently covered in a horrible blue fabric!!)
My intention is to strip this old fabric off and glue nice black leather in its place, trim it to size and then swap the door card inserts. Alternative I might get away with leaving the fabric where it is and sticking the leather direclty ontop - might not be too bulky and could stick better - dont know!
Anyone any experience of doing this sort of thing – mainly the best type of adhesive to use to glue leather onto the thin foam backing?? I was thinking of trusty evo stick contact and will probably use that to stick the insert back onto the door card, but wondered if there were any types that were better suited and also given the surface area to cover to make sure it sits smooth and flat. Used Bostick leather glue on numerous occasions but would need to test it, seen some 3M spray adhesives somewhere, or possibly some adhesive type tape? Not going to be very easy I think to spread glue on thin foam!
Paul
Paul
